Synthetic Oil in a push mower???
alamal's Avatar
05-15-05, 05:20 PM   #1
I'm looking to buy another lawn mower as I seem to go through them quite often (one every 5 years). Can I use synthetic motor oil in these babies (amsoil)?
Thanks so much and may God bless,
Peter
cheese's Avatar
GA
05-15-05, 10:25 PM   #2
Hello Peter!
You can use it, although I'm not convinced it will help. It shouldn't hurt either. Use an oil that will fall into the warranty requirements in case you have a warranty issue in the future. If in doubt about the warranty, call the mfgr (1-800 number should be in owner's manual) and inquire.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
tom93r1's Avatar
05-16-05, 02:38 PM   #3
Since your mower doesnt have a filter (most likely) it is not worth the extra expense of synthetic. You will have to replace the oil due to contamination long before it breaks down from heat cycling.
alamal's Avatar
05-16-05, 04:57 PM   #4
Thanks guys. I appreciate the feedback.
It's just that in my mowers it seems like the oil reeeeeally cooks. I had one mower that when the engine cooled the oil was like molasses.
Take care and may God bless!!!
Peter
dave237's Avatar
NC
05-16-05, 05:38 PM   #5
alamal,
I agree with cheese about checking your owners manual for requirements. I have a 25 year old briggs with many many hours of run time and a known chipped ring. Before I switched to synth, it used to burn around a pint of oil every three hours. After switching to Mobil 1 syth it's down to teaspoons. Also, the engine sounds tighter with less knock than before. Although, this is a 12hp lawn tractor engine I would assume the benefits would far out way the added cost of the oil. Always, change your oil according to manufactures' specs regardless of oil used.
Dave
