will this motor fit
Old 05-16-05, 05:45 PM
will this motor fit
i have a murry that has a bad 12.5 horse briggs motor on it but i have a 16 horse twin cylinder will it fit on it if not what would a good 16 horse be worth it dose not smoke or rattle runs good thanks
Old 05-16-05, 11:33 PM
cheese's Avatar
Received 22 Votes on 19 Posts
I believe it will fit if the crankshaft diameter and length are the same. They probably are as most are standard size, but check. It may take a bit of adapting to make the throttle cable, starter cable, fuel line, etc... fit.
Old 05-17-05, 06:30 AM
Many of the online dealers have dimensional drawings you can check. If these aren't current models, you can call B&S customer service and they can give you the information if you have model #'s.
I wanted to replace a Tecumseh H50 with a new engine and a lot of people - dealers, online forums, etc - told me that it would not fit. B&S faxed me detailed instructions and in fact the Intek Snow 7.5 fits on the same mounting holes as the old engine - same shaft diameter and location (but longer bolts were needed for the new engine). They were great.
Old 05-17-05, 08:28 AM
The 12.5 horse model # is289707 the 16 horse is 402707 type124401code9312075b I think it will fit on the murry . But im not shure about the exhaust on it I have all the throttle cables of the old mower.And wiring. Thanks for the help. I hope this motor will work
Old 05-17-05, 09:01 AM
Ham
Ham is offline
Will the twin cylinder engine fit under the hood of the mower?
