Pressure washers
Old 05-16-05, 11:59 PM
Pressure washers
I am in the market for a pressure washer and I'm not sure exactly how much power I will need for the various applications I plan on using it for. Does anyone know how much water pressure to use for different applications? For instance, I would be using this for tough cleaning jobs (ie, concrete stains, aluminum siding mildew) but also for washing the car and other light duties. I have read that you can destroy a wood deck and aluminum siding by using too much pressure. But what is the max pressure you would want to use on wood and/or aluminum siding? Would it be safe to assume that too much pressure could also take paint/finish off of a car? I was looking for one with about 3000 psi w/3.5 gph throughput but I noticed that not all of them have a pressure regulator to reduce the pressure output from its highest rating. So, any ideas on suggested pressure settings for these various tasks? Thanks.
Old 05-18-05, 01:21 AM
cheese's Avatar
Hello JCox!
I know a bit about pressure washers, but not their suitability for different applications. Check back often, someone will probably have some advice for you.
Old 05-18-05, 05:50 PM
bought one today
I just bought a display model closeout or discontinued preasure washer today 3400psi 4GPM 11hp B&S craftsman from sears at less then half price. I believe it has an adjustable preasure regulator. I have only used a preasure washer once before and learned quickly that the water preasure can remove concrete if you keep it in one place to long. I to will have to monitor this forum to learn more. I'm using it for home owner use and chose a more powerful one to make a little money on the side should someone want me to preasure wash something requiring more preasure.
The only thing I may not like about this B&S engine is I'm not 100% sure but it may have fixed jets in the carburetor which means there no adjustments for rich or lean. This preasure washer is listed as 135 lbs. dave
Trackbacks are On
Pingbacks are On
Refbacks are On
