Craftsman Lawn Tractor Help
Old 05-18-05, 08:08 PM
wvufan68
Model: 502.255531
12 horse Tecumseh
Keeps bending the exhaust push rod.
Old 05-19-05, 11:56 PM
cheese's Avatar
Make sure the rocker arm is straight, contacting the valve in the center of the rocker arm and not on the side.
Old 05-20-05, 05:30 PM
wvufan68
The rocker arm is straight and contacting right. Every time I try to turn it over, the rod gets bent. I replaced it with a new one hoping the old one was just weak from being bent and straightened again, but as soon as I tried to turn it over the new one got bent too.
I've tried everything I can think of and I'm at a loss. The float in the carb went bad and I had a problem with gas filling everywhere. Replaced the carb. Could that have caused some kind of screw up concerning the rod that I'm just missing?
Thanks for your help.
Old 05-21-05, 01:16 AM
cheese's Avatar
It sounds to me like the exhaust valve is stuck. If the valve can't move, then the pushrod will bend trying to move it.
