Toro 6.5 dies after start OR first-time mower owner's huge mistake
Old 05-20-05, 05:39 AM
glyndwr
OK, so I've rented for years, bought a house 3 years ago and up until recently had an electric mower. I just got a Toro 6.5 w/ Tecumseh engine, no choke but a primer.
Thinking it was right to do, I put 2-cycle oil in it, mowed for 10 minutes then it died. I then did the male thing and read the manual.
I changed the oil, the spark plug and air filter. Last night I got 30 minutes out of it before it quit. I start it and it runs 1 second, then dies.
Is this repairable? Or do I just admit I was a bone-head and get a new one?
Old 05-20-05, 02:54 PM
puey61's Avatar
Just how much oil did you add to it and by what means did you add it? Worst case should be a carburetor reconditioning. Chances are the carb is plugged up and a good soaking will do the trick.
Old 05-20-05, 07:33 PM
glyndwr
I put about 2 Tablespoons into existing oil....I just poured it in.
I've changed the oil again and added some gas stablizer but no luck.
Old 05-21-05, 01:09 AM
cheese's Avatar
2 tablespoons of 2 stroke oil in the regular oil shouldn't have hurt anything at all. I think your problem is unrelated.
Old 05-28-05, 04:49 AM
Take out the plug and look at it. It may well be fouled again. You can check to see if spark is present at the same time.
Old 05-28-05, 12:55 PM
glyndwr
I took the plug out and it was ok. I also drained the gas out, put new stuff in with a stabilizer and voila it was sluggish at first, but ran great (until I hit thick wet grass, put new oil and and ran it again.)
Thanks all.... turns out it was bad gas, not bad oil. I've had that problem before
Old 05-28-05, 10:57 PM
cheese's Avatar
Glad you got it! Thanks for the update!
