ryobi [weedeater engine running] problem
Old 05-22-05, 10:54 AM
sniper3270
I have a ryobi weedeater model#790r EZ a ladie brought it to me to work on would not run right tryed set screws started off with 1/1/2 high 1 low got it cranked tryed to adjust would run a little better but rough rebuilt carb. no change noticed leaking behind carb. manifold gasket fine carb tight push primer to get started gas started to pour out of carb. i don't know if it's the cap or what i need some help i think i tryed everything but the cap tight or lose still runs the same is there anything else to try???
Old 05-23-05, 12:28 AM
cheese's Avatar
You still have a carb problem. Did you install a kit?
Old 05-23-05, 04:10 PM
sniper3270
ryobi weedeater problem
Hey cheese..... yes i installed a kit and soaked the carb. for two days only thing left to do is manifold gasket and or cap the carb. is leaking between the carb. and manifold gasket but gasket is good maybe cap not venting or the new neddle i install is not good???
Old 05-24-05, 03:28 AM
puey61's Avatar
Pull the muffler off (and apart if possible) and check for carbon build-up at the outlet port(s) as well as the exhaust port for any blockage. If there is a screen in the muffler pay special attention to this.
Old 05-24-05, 03:36 PM
sniper3270
ryobi problem
I allready done the muffler took it off and soaked it for about 2 days this muffler doesn't come apart that's all i know to do the thing may be shot i'll try the new gasket behind the carb. and see what that does
Old 04-21-07, 12:06 PM
Ryobi 775R FuelFilter problem
I have a new fuelfilter for this weedeater. The problem is I can't get the filter with the tube on it to fully seat. I can just get it started, but it just won't go down anymore. Do you have any good advice on how to make it go down all the way ?
