MTD Wiring for Ignition
In have a Mtd 665 series riding lawn mower which has a 5 prong ignition switch. They are labeled as G, S, M, B, L ...none of the wires are connected to the switch. The wires are as follows 1 red, 1 red w/ white stripe, 2 yellow, 1 orange, and a set of blue that are together(know these are the lights).Here is the model of the tracker 13AQ665G013..Model/ 1A277C60175...series...if any one can help me please write back at xxxxxxxxxx
Thanks...Tim
Thanks...Tim
Last edited by GregH; 05-24-05 at 08:32 PM. Reason: Email addrersses within posts and offsite communication are not allowed.
Hello Tim!
The B is where the 12v power from the battery connects
M is the kill wire to the coil
G is a ground wire
S is the solenoid trigger wire
L is where the lights connect
You may have to trace the wires to see where they go in order to figure out which color wire is what.
G is a ground wire
