Help! tines wont engage on tiller
Old 05-24-05, 02:53 PM
denver_babs
I have a 5.5 hp craftsman front tiller...was working great now the tines wont engage. The cable appears fine and does pull the lever. Where do i start?
Old 05-24-05, 11:01 PM
tiller
you start by checking the belt--is it still there--does it turn when you engage the lever? If so you check the driven pulley and ensure it is turning the shaft it is on. If the shaft is turning then you go to the shear pins on the tines and if they are in place you will probably have internal gear box problems. I think its a chain drive inside and many times the master links have come apart.
S/T
Old 05-31-05, 07:52 PM
denver_babs
thanks!
the belt had slipped off and the cable needed adjusting. Garden is tilled and planted! thanks for the tip!
