Ariens RM830E (8hp B&S engine) - stalls after about 20min
woolfie's Avatar
05-30-05, 02:09 PM   #1
woolfie
I have inherited a free Ariens RM830E from a kind friend, but it stalls after about 20 mins of use -- i.e. once it's got good and hot
I've disassembled, cleaned and re-assembled the carb (and it still worked!) and cleaned, re-set the spark plug.
Any ideas what could be causing this?
Also (maybe related), how can I check the charging circuit/voltage when the engine is running. The mower currently has a dead battery, and I start it by boosting it from my car (so when it stalls, I have to push it from the back yard to the front of the house ). I'd like to make sure the charging circuit works fine before buying a new battery.
dick1947's Avatar
NY
05-30-05, 08:59 PM   #2
Have you checked the gas cap? If it's not venting properly the gas will stop flowing from the tank. Must create a vacuum.
Dick
cheese's Avatar
GA
05-30-05, 09:05 PM   #3
Have you checked to see if you have spark at the plug when it stalls?
To check the charging system, you'll need a voltmeter. With the engine running at full throttle, you should get a reading of at least 13.5 volts at the battery....BUT...if the battery is shorted internally you may not get a reading this high but still have a good charging system. Chances are it's ok, and if the battery is more than 2 yrs old, it's probably bad.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
woolfie's Avatar
05-31-05, 07:29 AM   #4
woolfie
> vacuum.
The cap looks OK and appears to be allowing an air flow. This past weekend following its usual stall, I did notice that there was gas splashed out from the gas cap. This could have happened during the long push back from the back yard, but the tank was half-full (half-empty?!), so I wouldn't have expected much slushing to occur.
Is it possible there would be back-pressure in the gas line?
Not yet, I can do that next time.
Good to know. I'll check the volts next time as well. If it shows a good reading, I'll go buy a battery so that I don't have to keep boosting it from the car!
Thanks.
