Simplicity 3510 not starting
Old 05-31-05, 08:01 AM
Littleben
I'm a rookie when it comes to this stuff. Wife was cutting grass. Tractor started to sputter like it was running out of gas. Still had some gas but she added more. Now it won't start. Checked fuel line and she's getting gas. Put in new spark plug. I think she's sparking 'cause for some reason the wife tried wiggling the wire and jumped pretty good when she got a shock. A buddy of mine mentioned a coil problem. She' cranks and cranks but just don't fire. Can I check the coil for something. And if so......where the hell is the coil? I tried looking online for a manual but no luck.
Any help would be muchly appreciated.
Old 05-31-05, 10:29 AM
cymer
Not starting
I'm not big on htis stuff myself, however I had a similar problem with my Murry rider. I replaced the fuel filter and it started fine.
Old 05-31-05, 10:52 AM
Littleben
Yea, I thought of that too. When I removed the fuel line from the motor end, gas came pouring out.....through the filter so I don't think it's clogging at all.
Old 05-31-05, 12:27 PM
Put a tablespoon of gas in the spark plug hole and replace the plug. Then see if it fires. If it fires then it most likely its a fuel problem.(Dirt in Carb maybe) It if doesn't fire may be a ignition problem coil, plug, points(if it has them).
Old 05-31-05, 01:59 PM
Littleben
I'll give that a shot tonight. Thanks for the input.
