Tecumseh loses power when hot???
Old 06-01-05, 03:55 PM
I've got a H35 (3.5 hp horizontal shaft) Tecumseh on a crappy old MTD chipper/shredder that runs great until it gets up to temp. It then bogs down and starts to stall under load. I have to choke it to keep it going, but it's useless for doing any work.
I was thinking maybe a valve not seating properly or a leaking gasket.
Any thoughts?
Old 06-01-05, 06:14 PM
Edited.
Moderator's note...your advice and expertise is welcome, but posts with no useful content, or that may reasonably be inerpreted as offensive, are not. Thank you.
Cheese
Old 06-01-05, 07:11 PM
Gee, why didn't I think of that?
Old 06-01-05, 08:28 PM
Loosen the gas cap and see if that is the problem due to cap vent being plugged.
Mike
Old 06-01-05, 09:05 PM
hotandhumid
"Kind of like an oxymoron!
Got a crappy MTD shredder that runs GREAT??
Useless for doing any work??
Sell it and get a new one!
T.J."
I may be new here but what is this guy's problem? Always using exclamation points and offers no help. Why is he here?
Old 06-02-05, 12:53 AM
cheese's Avatar
Agreed, no help was offered and the post has been edited.
I agree with Mike, the gas cap vent may be (probably is) plugged.
Old 06-02-05, 06:23 PM
Thanks all.
Well, I tried the gas cap and there's no change.
It seems that for the first minute it runs ok. Then it starts to bog down under load. That lasts for several minutes and then it finally wants to stall and I have to give it choke to keep it going.
To me it sounds like a heat related problem (all fins are clear). Almost like something warping or not seating correctly.
Would a leaking head gasket cause this symptom? Maybe the leak opens up as it gets hot?
I'm just guessing here.
Thanks.
Old 06-03-05, 12:43 AM
cheese's Avatar
My next thing to check would be the valve clearances. Sounds like they may be too tight.
