Trans Axle
Trans Axle
Guy's,
I have an older "1992" 5 speed transaxle mounted under a Murray 36" cut mower. It shifts great when cold but once it heats up it does not want to shift. I have removed it from the mower and looked for drain or fill hole. There was not one as I could see however, I did note that it would'nt be hard to take it apart, just did'nt want to go that yet.
Could the hard shifting once hot, be due to lubrication or is it a wear issue? What's the best fix to the problem?
Thanks much!
Dave
Thanks much!
Dave
Hello Dave!
Probably moisture buildup in the tranny and lack of lubrication. It's not hard to disassemble as you noted, and if you are pretty mechanically minded, you should be able to remove the shifter and clean off any rust. Use "00" grease to lube it with and make sure everything is in the right spots when you reassemble or the case will break. Pay particular attention to the bronze bushings at the ends of the shafts. They have flat sides and notches that have to be lined up with the corresponding spots in the case.
Cheese,
Thank you much for your help and sharing your knowledge.
Dave 237
Dave 237
Anytime! Keep us posted with your progress.
Previous Thread
Next Thread
