Clutch Pedal of Toro 314-8
Old 06-02-05, 08:04 PM
wheelhorse
Hello,
The drive clutch pedal on my wheelhorse 314-8 releases very slowly at times. Sometimes it has to be 'coaxed' back into position in order to get the tractor into drive. Is there a way to adjust this?
Thank You
Old 06-03-05, 12:36 AM
cheese's Avatar
Hello Wheelhorse!
Sounds like you need to lubricate the rod that the clutch pedal is on, and any moving linkages related.
Old 05-17-08, 08:46 AM
Wheel Horse 314-8 clutch
Hi,If you remove the shield covering the drive belt you should see a small gas rod connected to the idler pulley.I had to replace this on mine when the clutch wouldnt work right.I have a 416-8 and the 300-400-500 series all used this on the manual clutch.Hope this helps you.
