Proper Way to Troubleshoot
Old 06-08-05, 07:09 AM
Ham
Ham is offline
What's the best way to learn how to troubleshoot an engine and not be just a parts changer? I hate to change one part and it be something totally different.
Old 06-08-05, 08:59 AM
Azis
First is to properly identify the equipment you intend to troubleshoot...aquire ne and all publications, manuals, etc. Most if not all will usually include at least a brief troubleshooting table for the most common problems.
Old 06-11-05, 02:17 PM
zebra618
In all of the manuals that I have there is a "Decision Logic Tree." This will help to guide you through the process with your specific machine.
This is invaluable when you do not know the operation of a machine.
Outside of that there are many techniques for troubleshooting.
Most of them require that you have an understanding of the normal operation, and then apply the scientific method - Formulate a hypothesis ( why isn't this machine <fill in the problem>, and then develop a way to test that hypothesis. Remember, each test will prove or disprove your theory. In either case, the best you can hope for is to learn a little more about the problem, then repeat.
Good luck!
Old 06-11-05, 06:20 PM
There are three main things that must be present: (1) Compression (2) Carburetion (fuel supply) and (3) a correctly timed spark.
Old 06-11-05, 08:26 PM
bambiblaster's Avatar
HAVE THE PROPER MANUALS ...LOOK AT THE OBVIOUS .. DONT GET TO MUCH IN DEPTH THOUGHT OF WHAT IT COULD BE ... AND WHEN FRUSTRATED , WALK AWAY AND COME BACK LATER. ( THIS IS FROM PAST EXPERIANCE TRAINING NEW TECHS, THEY WALK AWAY AND TAKE A BREAK AND COME BACK AND FIX IT)
