Briggs 18hp governor adjustment
jm2591's Avatar
PA
06-08-05, 10:45 AM   #1
I have a briggs horizontally opposed twin ll that wasn't running right. After a lot of checking I found the nut was missing where you tighten the governor arm to the shaft allowing the shaft to turn out of adjustment. I replaced the nut but could someone tell me how to correctly adjust the arm to the shaft?
Thank you!!
puey61's Avatar
NY
06-09-05, 03:24 AM   #2
With the nut (you mentioned was missing) loose, turn the governor shaft counter-clockwise as far as it will go (easy does it here) and move the throttle linkage to the wide-open-throttle position (also counter-clockwise) and tighten the nut.
