murray riding mower won't engage
Old 06-18-05, 11:43 AM
staples30
I have an 12.5hp murray wouldn't start replaced starter solenoid and ignition switch. starts fine but when I try to engage blade motor dies have checked belt and blades are turning freely any idea what could be wrong
Old 06-19-05, 01:16 AM
cheese's Avatar
What about when you release the clutch pedal. Does it shut off then too? If so, the seat switch is bad or not connected well. Otherwise, I'd say the blade switch could be faulty, or the carb could be in need of repair. Does it just die like you turned off the switch, or does it putt and skip until it dies?
Old 06-19-05, 11:40 AM
staples30
blade won't engage
no it doesn't cut off when clutch is released only when you try to engage blade. instantly doesn't putter can we by pass blade switch we need help
thanks
Old 06-21-05, 01:47 AM
cheese's Avatar
On the side of the engine is a single black wire near the starter area. Unplug it and try again. If it still runs, you have a safety switch problem, if not, you have a carburetion problem. Note that when you do this, you cannot shut off the engine until you plug it back in or choke the engine out. Let us know what happens.
