Mower engines are burping gas
Old 06-19-05, 11:17 AM
I have two pieces of equipment.
One is a mower that was errently filled with diesel fuel. The fuel was drained and gas put in. No the mower blow raw gas (lots) out of the air intake while it's running. Is it worth taking to my fix-it guy or should I start over?
I have a yard vac that runs rough and spits a tad of gas out the air intake too.
What causes this symptom whether much or little.
It's ok to talk tech. I understand engine talk.
Old 06-20-05, 03:29 AM
puey61's Avatar
The diesel filled engine will need a carburetor reconditioning and the fuel out the intake indicates a problem with the intake valve clearance whereas it is not sealing fully and allowing gas to be sent back through on the compression stroke.
Old 06-20-05, 11:52 AM
Ouch!
Intake valve problems......I hope not.
It's a new mower other than the mistake with the fuel. I bought it from Wally World last year and never really messed with it right away. It was from a scratch and dent sale, to become a quick job mower for around the property.
I'll get you some numbers and maybe you can let me know if I can do the recon myself, like for the other fellow in here.
