New pressure washer
Old 06-21-05, 12:01 AM
fromoregon02
New pressure washer
I thought I was filling up the oil in my pressure washer when I put oil down the oil vent hole. I only discovered the error when that hole topped up and the dipstick showed no oil. Did I make a major mistake?
Old 06-21-05, 12:09 AM
cheese's Avatar
Not a major mistake, just drain out what you can because it will probably blow out if you start it. Fill the pump to level, run it, then recheck in case some makes its way into the pump reservoir.
