Craftsman Blower
Craftsman Blower
I have a blower that I rebuilt the carb put new fuel lines and filter in the tank unable to get gas to primer bulb,also replaced the primer bulb.The fuel lines are correct the primer is on the carb pump side has two lines going to the tank,the return line is closer to the primer without the filter.This is a wa walbro carb.I enjoy reading this forum,has help me a lot.
Thanks
Jerry
Thanks
Jerry
Only two things come to mind, either when replacing the fuel lines you didn't push the supply line down into the tank far enough, or, dare I say it, hook up the fuel lines correctly to the primer bulb (I know you said thay are correct, but it's usually the obvious things that give trouble)
