hydrostatic drive maintenance
I have a mtd 18 hp 46 inch cut lawnmower, Now I know this thing has to be 10 years old or more is there any maintenance I can do to the hydostatic drive to help extend the life time ?
Crom
Crom
you could change the oil in it, but it isn't recommended. They are concerned you might get some dirt in it. If you do change the oil, I use 5 - 30 synthetic.
If it hasn't leaked, then the oil should still be at the factory level. If it's slower than it used to be going uphill, it could be the belt is glazed a bit and slipping a little, or the cooling fins on the pump could have grass clippings and dirt caked up in them. If neither of these are the case, an oil change may well help it. Some units aren't made for the oil to be changed.
