pressure washer question
i purchased a craftsman 1750psi pressure washer recently
the nozzle i am to use when i use the cleaning solution has no pressure. and also the bottle supplied colapses in on itself when in use.
i thought the cleaning solution and nozzle pressure would work together to clean my house. this is not the case.
i've read the manual (crappy as it is) and nothing in there tells me anything about this problem. all the other nozzles work great and have lots of pressure.
thanks in advance
thanks in advance
that , and most craftsman washers, do not feed cleaning solution at high pressure--only on low pressure. The idea is to let the solution stay on the surface you are cleaning for a short period of time and then wash it on high pressure.
S/T
S/T
