Homelite chainsaw won't run
Old 07-12-05, 03:42 AM
PatRussell's Avatar
Was using my 9 month old Homelite Bandit to take down some bushes yesterday. Everything was fine until several minutes into it when the saw would quit at idle. I could restart it on one pull and it would run again until I let it idle, then quit. Eventually the saw would only start when at half choke, full throttle. As soon as I let up on the throttle it would die.
Not sure where to go here (can't find my owners manual for the troubleshooting guide).
Thanks.
Old 07-12-05, 06:56 AM
I have a Homelite 23AV and not sure if it's the same as yours. Mine started doing something similiar and I found the carb to be loose on the cylinder. Tightened it and installed some threadlocker and has worked fine ever since.
Old 07-13-05, 01:11 AM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Any chance it was used without oil in the gas?
