Kohler Engine
terlaw's Avatar
07-19-05, 09:19 AM   #1
terlaw
Kohler Engine
I have a JD that has a Kohler K181 8 hp engine, I am trying to rebuild. I have not had a small engine apart since small engine class in highschool many moons ago. I have taken it down to removing the broken piston, that was the easy part. I now need to remove the old valves. Do I need to remove the flywheel to get them out? If so how do I remove it? Can anyone help me out here? Thank you in advance.
Walter
Azis's Avatar
07-19-05, 07:15 PM   #2
Azis
I am not all that familiar with kohler and am unable to find any info with that model #.
Check here http://www.kohlerengines.com/service...tification.jsp hopefully you still have the placard.
Link for a service manual if kohler has documentation on it.
http://www.kohlerengines.com/service/manuals/index.jsp
terlaw's Avatar
07-20-05, 06:15 AM   #3
terlaw
Az thanks for the link. I was able to find a pdf of the service manual. Should make the job a lot easier.
Regards
