Kohler Engines Parts Manuals
Old 07-24-05, 08:05 PM
Is it just me or are there no sites out there with Kohler Engine part manuals? If you know of one please let me know.
Looking for parts manual for K341AQS spec 71176a
Restoring an old Bolens tractor-not sure of year but OLD.
Has a cast iron case around the hydro gear. HEEAAVVY!
Thanx in advance
Old 12-31-06, 08:50 AM
Did you find one?
I'm looking for the EXACT same manual!!! Any luck??
Old 12-31-06, 01:16 PM
repair_guy's Avatar
New Member
Hay you two----- Not sayin' that it does or that it doesn't but this stie has a lot of your 'older' engines manuals listed. http://www.yesterdaystractors.com/gardent/messages/archive252.htm
HOPE IT DOES HELP,GOOD LUCK
Old 01-02-07, 11:03 AM
puey61's Avatar
kohlerengines.com On the left side you will see a "look up parts" link and from there you need to enter as a guest and then in the upper right of the next page you will see a place to type in your specification number and away you go.
Old 01-02-07, 02:00 PM
Azis
Kohler does not seem to have support for that engine. I find this often.
You might try using the model number from the Bolens tractor and searching here
http://mtd.arinet.com/scripts/EmpartISAPI.dll?MF&app=MTDC&lang=EN&TF=Mainframe&loginID=MTDCon%20&LoginPWD=
Old 01-02-07, 04:20 PM
Your engine is listed on Kohler website under Parts lookup as Puey61 said.
Model 341
List as: 341-71176
Shows parts diagrams and part numbers
Application Bolen Tractors
Old 01-03-07, 05:48 AM
Azis
So it is listed and shows ONLY using "Internet Exploder" :P
Not at all my idea of a "Manual" however. The MTD site still may have the entire PDF "IPL"
Old 01-03-07, 12:49 PM
puey61's Avatar
I'm sure supertech will come up empty on the MTD site as his engine is a 70's vintage and MTD doesn't provide support for equipment with the name Bolens unless it is relatively new (since MTD has put their name on them). But it's worth a look if he has the time.
