echo chain saw problem
i have an echol chain saw...just a small saw about a 15 inch bar or so...
when i crank it and attempt to cut something, it dies...when i pull the trigger and give it a lot of gas to cut a limb or something, it dies...so, i have to pull the choke out about half way...it then works, but not well..
any ideas???
thanks...
any ideas???
thanks...
Hello hobbs_m!
The saw is not getting enough fuel. Look near the carburetor, around the air filter. There should be 2 holes marked H and L. Use a small screwdriver and back the screw in the H hole out about 1/4 turn or so and see how it does.
