re: Echo ES 1000 blower/shredder vac
Hello:
The Echo blower has always started on the first pull. A week ago I loaned it to my brother (always a big mistake.) It came back filthy but still had some fuel in it. I used it for a few minutes and it died as the fuel tank was empty.
Filled the tank and it has not started since. I cleaned the air filter, put in fresh fuel at the correct ratio (btw, I gave it to my brother with a 1 gallon can of premix so know he didn't screw it up that way.)
Also put in a new plug and it seems to have spark but not as bright as I'd like.
Only thing I have not done is replace the muffler. I'll likely do that anyway on Monday when the parts shop is open.
Anyone have any ideas on the no-start issue? Seems unlikely is is plugged but who knows.
Regards,
Snowman 53
Regards,
Snowman 53
The muffler should have a spark arrestor on it. Just a small rectangle screen held in with a plate or screws. If plugged just clean this. Echos and Stihls I see this alot. The owners manual should make mention of it for regular maintenance if not troubleshooting.
