Stripped spark plug threads in lawn mower..
Old 08-01-05, 12:43 PM
Mike Burdick
Well I guess it’s my turn for some bad luck. I replaced the spark plug in my lawn mower and apparently I tightened it too much and stripped the threads in the aluminum head. What is the best method of repair? Is it possible to get a little larger plug and rethread or will a helicoil work? This is a 2-cycle engine so the cylinder is part of the head.
Thanks in advance
Old 08-01-05, 01:18 PM
L
i strripped out a bolt on an aluminum carb once and took it to small engine shop. he rethreaded it in about 30 seconds and it worked just fine.
Old 08-02-05, 12:47 AM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Any way you do it, the head (jug) will need to be removed, so I would reccomend just replacing it. I believe there are helicoils made for this application but I've never used one for a spark plug.
Old 08-02-05, 05:44 AM
puey61's Avatar
Received 2 Upvotes on 2 Posts
If the spark plug is a tapered seat then you'll have to replace the jug as there is no thread repair kit for these. If it is a standard, gasket type spark plug then you do have the option to repair the threads. I prefer Recoil brand versus Helicoil brand.
