briggs/stratton 3.5hp - can't find carb mixture screw
Old 08-06-05, 04:49 PM
cmkamimura
Unhappy briggs/stratton 3.5hp - can't find carb mixture screw
Does my briggs/stratton 3.5hp lawnmower engine have a carb mixture screw? I can't seem to find one. The engine is running really rough and needs to be choked about half way for it to run. Is it possible that I don't have one on this engine? How would one adjust the carb if this is the case. Thx!
Chuck
Old 08-06-05, 08:24 PM
D
cmkamimura,
Welcome,
If your mower is a newer model, last couple of years,you most likly will not have adjustment screws on the carb. Throughly, clean your air filter and if this does not help a carb cleaning may be in order.
God Bless,
Dave237
Old 08-06-05, 10:08 PM
L
on the older ones adj. is at base of carb. stick screwdriver in sheet metal hole in front by head. eventually you will feel it. if it is a newer one and starts ok but runs rough. replace diaphragm. it is a rubber gasket that sits between carb and gas tank. you will have to take 5 screws that hold carb to tank and lift it out carefully. putting new exactly in same way. they only cost 2-3$ but will make your mower use extra gas and lose power. they get hot and wear. if this is the case it will run like its supposed to immediately. i do not suspect primer bulb because it is starting. i dont think your carb is bowl type but diaphragm type. when pushmower bowl types go bad they wont start. run for a few seconds and stop, or surge{rev up and down). also if you have it off make sure carb is seating to intake pipe. thers is a little ring plastic or rubber that seats them together preventing vaccum leak. diaphragm types also have a plastic screen in tank that could get partially plugged but if i had to bet i would say ck diaphragm.
