The Adjustment of jet on the bowl of 10 hp tecumseh
Old 08-06-05, 07:45 PM
sktruc
Talking The Adjustment of jet on the bowl of 10 hp tecumseh
I have a 10 hp tecumseh engine and i need to know what the proper adjustment is on the jet on the carburator bowl is ?
Old 08-06-05, 08:14 PM
D
sktruc,
Main Jet adustmet is: Turn screw in until seated! Easy here! Don't tighten to tight. Just until you feel it seat! If you srew it in tight, you will need a new needle screw. Back out 1 to 1 1/2 turns and adjust from there in 1/8 turns to perfection.
God Bless,
Dave237
Old 08-06-05, 09:56 PM
L
hi idle is on bottom of bowl. adjust when hot under load somewhere between 1-2 turns out depending on conditions. you want a slightly rich mixture so it wont stall under load. the low idle is on side of uppercarb facing you adjust when hot at low speed. book says 1 to 1and 11/4 out but one to 2 turns should do it. make adjustments slowly. i notice on my older mowers at the beginning of year when it is cold i have to screw carb adj. screws out and when it gets hot i have to turn them back in for smoother running.
