Poulan Shark chainsaw missing
Poulan Shark chainsaw losing power
I have had one of these for a couple years and does have quite a few hours on it. I only paid about $80 for it. Recently, it has started missing and does not have much power. I've had the carburetor out and cleaned that. The gas lines seem to be clear. I fiddled around with the carb adjuster screws and once in awhile it will achieve full power but not for long. Any help will be greatly appreciated. Thanks
Originally Posted by San-Man
Is it safe to assume you've already checked the spark plug and replaced as necessary? Also did you check for corrosion under the plug wire boot?
