Weedeater FL 1500 Blower
Old 08-12-05, 03:07 PM
dike98
What is procedure for rewinding the recoil spring for the pull starter?
Have a fairly good idea but want to be sure I'm proceeding correctly.
Thanx,
Jim undefinedundefined
Old 08-14-05, 01:54 AM
cheese's Avatar
Received 46 Votes on 41 Posts
With the spool in place, wing it the same direction it would go if you pulled the rope until it stops...then back it up until the hole in the spool lines up with the hole in the housing and feed the pull rope through.
Old 08-15-05, 10:38 AM
dike98
FL 1500 Blower
Thanx Cheese....will rewind and give it a shot.
Jim
Old 04-15-08, 08:40 AM
L
Jim
I am having the same problem but am a bit of a novice. Can anybody give a step by step on how to rewind the recoil spring?
Old 04-17-08, 12:30 AM
cheese's Avatar
You have to disassemble it far enough that you can grab the spool that the rope winds up onto, then physically grab it and turn it, winding up the spring, until it is wound. At that point, you would attatch the rope with handle tied to the other end, then let the spring wind up the new rope onto the spool.
Old 06-30-08, 11:21 AM
C
How to open it up??
I also have a sticky starter on an FL 1500 blower. I can
get the blower cover off (allen screws) but how do I hold
the crank when I try to loosen the nut that holds the
impeller on?? All I can think of is to remove the plug and
jam the piston?? Seems kinda drastic.
thanks 'n all
chuckc
Old 06-30-08, 08:21 PM
cheese's Avatar
Yep, jam the piston with a piece of pull rope in the plug hole.
Old 07-01-08, 09:41 AM
C
How to Open it Up
Many thanx, Cheese! Works a treat now.
chuck
