How To Remove Lawn Mower Blade?
Old 08-17-05, 06:19 AM
D
Dpdblues
I tried to loosen the nut on the Lawn Mower blade but the blade turns as I try to loosen the nut. Any one have any tips or tricks to stop the blade from moving while loosening the nut?
Old 08-17-05, 06:53 AM
Received 93 Votes on 82 Posts
I wedge the blade against the mower deck with a chunk of 2x4.
puey61's Avatar
Hold the blade using a heavy work glove. Be sure to disconnect the spark plug wire before doing such. If, for some reason, the blade hub adapter has a sheared key, holding the blade will do no good, you'll need compressed air and/or heat to remove the nut.
Old 08-17-05, 10:26 AM
bontai Joe's Avatar
An air operated or electric impact wrench works well if you have one. The impacts occur faster than the shaft will turn. ALWAYS remove the spark plug wire when working under any mower!
Old 08-18-05, 04:52 AM
H
I've found holding the blade with a good work glove does the trick. Use steady, even pressure when removing the nut and don't overtighten it when you put the blade on, but make sure it is snug.
Old 08-18-05, 11:09 PM
cheese's Avatar
Received 30 Votes on 25 Posts
I agree with the impact response. If the entire shaft is turning, it won't do any good to hold the blade while turning the bolt as you have found out. The impact will do it, however. Must be a murray product with the spring washers holding the blade tight.
