1997 MTD Rider Won't Start
msaffer's Avatar
08-25-05, 05:46 PM   #1
msaffer
Hello,
I have a 1997 ACE Special Edition MTD 42" riding mower that I bought from my neighbor. I've seen him mow his lawn with it, but the last time was about 6 months ago.
I turn the ignition key, blade is disengaged, transmission is neutral, clutch/brake is depressed, and nothing happens. No lights. (not sure if lights even wok yet) No starter motor kicking in.
I checked the safety switch under the seat and when I sit down, it separates some contacts which I think should allow electrical flow, but nothing. Dead as a door nail.
I took out the battery and put a fresh charge on it, I took out the starter, and tested it on a bench. It spins and the little gear pops up which engages the flywheel. It all looks normal.
So I am wondering what I am missing here. Can anyone tell me what else, or where else I should check to try and figure out why I am not getting current? Maybe there's another safety switch hidden somewhere that I am unaware of?
Any help would be greatly appreciated.
Regards,
Michael Saffer
Jacksonville, Florida
[email protected]
dave237's Avatar
NC
08-25-05, 06:49 PM   #2
msaffer,
Check your solenoid and key switch with the switch being the most likely fault. Try jumping the input terminal of your solenoid (small red wire) to the (+) of the batt;(while sitting on the seat, of course). If it turns over then the start switch is the fault. If nothing, look to your solenoid as the culprit.
God Bless,
Dave237
