09-01-05, 05:24 PM
Mower kills when I engage blade
My engine wants to cut off at times when I engage my blades, it works well at times but all of a sudden it starts to act up, sometimes if I push in the clutch it helps but not always..
I figure it to be some sort of safty device but not sure reason I asked here
2002 Yard-Man Riding mower
20 HP Intek engine with a 42 inch cut.
Anyone here know what might be causing this, if so how can I fix the problem?
09-01-05, 06:02 PM
Could be related to the seat but I disconnected that device when I bought the mower a few years ago, now that you say it though it could be a wire under the seat that is giving the problem.
GA
09-02-05, 01:18 AM
I'd say, from your description, you need to clean the carburetor. The carb opens throttle a bit when you engage the blades, and if the fuel isn't quite flowing like it should through the jets, it will stall. Try this: Run the engine with the choke on partially and engage the blades. Does it engage better? If so, the carb is the problem.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
