Dump gasoline
how much old gas, if its a tiny bit or even alot, you can add some of it to a cars almost full gas tank, it'll do fine and use it up that way. you can do the same with old oil/ gas mix for 2 cycles.
ahh, you can buy whats called fuel drier, or either use a strong clear isopropyl rubbing alchohol, it'll suck the water up and make it burnable, though its two gallons.... camp fire maybe? naaa
Many automotive parts stores will take used oil. Advance does. I mix the gas in with oil and take it to them.
