2 cycle gasoline
Old 04-15-00, 01:40 PM
Cool
Now that Spring has finally arrived in the Beautiful Shenandoah Valley of Virginia, I find myself using my 2 cycle chainsaw. But, now knowing that it is unlikely that I will again be using it until this Fall, I don't know what to do with the more than a gallon of gasoline/oil mixture. My question is: Can I use this in my lawn tractor or pick up truck without harm to their engines? I used an 8 oz. bottle of oil in two gallons of gasoline. I need the gasoline can that I mixed it in for lawn mowing! Thanks, again for your assistance.
Spencer
Old 04-16-00, 08:39 AM
Thumbs up
Hi:Spencer
I do not know of nor heard of or experienced any harm using the fresh leftover 2 cycle fuel mixture in a 4 cycle engine.
The 2 cycle oil is a lubricant only and will not cause any engine problems.
Another idea would be to buy a smaller gasoline container for the 2 cycle fuel and add a fuel stabilizer. However, personally I do not recommend this method for extended periods of time.
Storage tips:
Empty the fuel tank. Run the chainsaw engine dry. Remove the spark plug, add a teaspoon of oil into the spark plug hole. Pull the starter rope of few times, then reinstall the plug.
Good Luck
Sincerely,
TomBartco
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Old 04-17-00, 07:14 AM
Post
Not a problem. I use only one can for my line trimmer and lawn mower. Long term usage requires more frequent combustion chamber cleaning but short term will not be a problem. Another option is to pour it in your car with a near full tank. The dilution will make the oil content a non-factor.
http://nevada4.tripod.c
om/index.html
Old 04-17-00, 03:31 PM
Talking
Thanks for your replies. I thought once long ago, in a land far away, I had read that using this oil/gas mix wouldn't adversely affect my vehicle or 4 cycle engine. Just wanted to make sure. Can't always trust my memory.
Thanks again, and, I love this site!
Spencer
