difficulty starting tecumseh
I have a year old Sears pressure washer and it takes a great deal of effort to start it each time I use it. I have contacted customer service without much satisfaction. Does anyone have any suggestions other than "use Briggs and Stratton or Honda"?
Hi
atrick45
You didn't mention what difficulties your having starting the pressure washer. I'll assume it's after a long period of non useage.
Therefore, I'll make a few suggestions.
If you flushed out the old fuel and added fresh fuel and are still having a difficult time starting, there is most likely clogged ports in the carb.
A carb removal and internal cleaning will then be needed. You can also try a shot of quick start in the carb and see if that helps.
Try leaving the choke ON slightly once the engine has started. If that improves the running, it's a sure bet the carb is clogged.
Try installing a new spark plug too.
After you try these steps, advise your findings and add more detail <be more specific> and I'll try to help more.
Good Luck
Sincerely,
TomBartco
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Good Luck
Sincerely,
TomBartco
Personal Quote:
