Mantis tiller
Closed Thread
Old 04-28-00, 11:32 PM
Question
Have a small Mantis rototiller w/pull cord starter. That thing is a BEAR to start. It's just a little one, like $200-$300 - my mother-in-law's. She's had it probably 5-6 yrs. Anyway, the cord almost seems to wind incorrectly, no matter how fast or slow you let it recoil. When you pull on it, it like stutters or jerks a number of times - it's really hard to get a smooth pull, so, of course, it takes forever to start. Really kills the fingers. Also, once it does start, most of the time it dies out 'cuz you can't get to the choke fast enough to play with it to keep it going, or the throttle. Just not enough hands! The spark plug is right in the front, and once my son put his finger on the rubber cap and it stalled out. Does all this mean it needs a new spark plug? Is it something we can do ourselves, or should it get a tune-up? Problem is, I need it and most every place is 2-3 weeks ETA. Any suggestions??
Old 04-29-00, 01:24 AM
Wink
In the past 10 years I have had 2 Mantis. I wore the worm gear out in first one by not getting regular maintance. My dad bought one at my suggestion 8 yrs ago and his is still going strong. We have never had the same problems you describe, however if you let the gas run completely out they can be awful to start when you refil them. Touching the plug should not cause the engine to stop that sounds like a loose connection. A very common problem with the small tillers is that they are often not stored level, this can also present a problem when trying to crank simular to flooding the engine. I suggest you get a good tune up. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Adrianne:
Have a small Mantis rototiller w/pull cord starter. That thing is a BEAR to start. It's just a little one, like $200-$300 - my mother-in-law's. She's had it probably 5-6 yrs. Anyway, the cord almost seems to wind incorrectly, no matter how fast or slow you let it recoil. When you pull on it, it like stutters or jerks a number of times - it's really hard to get a smooth pull, so, of course, it takes forever to start. Really kills the fingers. Also, once it does start, most of the time it dies out 'cuz you can't get to the choke fast enough to play with it to keep it going, or the throttle. Just not enough hands! The spark plug is right in the front, and once my son put his finger on the rubber cap and it stalled out. Does all this mean it needs a new spark plug? Is it something we can do ourselves, or should it get a tune-up? Problem is, I need it and most every place is 2-3 weeks ETA. Any suggestions??<HR></BLOCKQUOTE>
Old 04-29-00, 06:25 AM
Post
Hi:Adrianne
I too have one of these tillers. Best of the bunch in my garden shed. I have not noticed any problems with my pull starter.
Hard starting is common with ANY engine if left setting for a long period of time with fuel in the tank.
Besure to store the machine level and with an empty tank if not used for more the a month. Run the engine until it total dies to clear out any remaining fuel.
You can also use a fuel storage additive without causing any harm to the engine. Add this stuff to the main storage can and then into the tiller fuel tank.
For the time being, try replacing the old fuel with a fresh batch both in the tank and in the fuel can. Check the fuel primer bulb and be sure it fills when pumped.
Try starting the engine with the choke closed and in the idle position. &lt;No throttle&gt; Then with the choke half opened and the throttle fully opened.
After several rope pulls, if this fails, the carb will need to be flushed out and or rebuilt.
Also try replacing the old spark plug with a new one and be sure the plug wire is firmly pressed on to the plug.
Good Luck
Sincerely,
TomBartco
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Old 04-29-00, 08:59 PM
Post
Thanks for your help. Will get that tuneup, see if it takes care of the problems. Adrianne
Old 05-15-00, 06:09 PM
Post
I have a Mantis and I've noticed the same thing about the pull start. Ours sits over the winter, and I've found that removing the spark plug and cleaning it (or getting a new one) just before tilling in the Spring makes it start right up, though it never pulls smoothly.
Old 04-09-09, 07:04 PM
More Info to add about the Mantis tiller
A friend of mine has one of these Mantis tillers but it would only sputter and it had no power, he asked me to look at it for him. I started by replacing the spark plug but there was no change so I said to myself must be the carburetor. After spending $58 dollars on the carb that didn't fix the problem. The problem was the spark arrester in the muffler it was plugged. Cleaning the spark arrester was quite easy you just remove the plastic cover with tree Philips head screws, then on the muffler there three more Philips head screws that need to be removed and the little spark arrester comes right out, itís a small screen. Hope the info might help someone else out there with their little tiller. By the way if your carburetor is made by Zama the part number for the carb is C1U-K54A I installed it this morning so I know the part number is good also for those out there that aren't sure how hard it is to change a carburetor it is two screws and two rubber hoses, real easy.
Old 04-10-09, 10:27 AM
Shadeladie's Avatar
Super Moderator
Received 38 Votes on 30 Posts
I'm sure after 9 YEARS the OP has fixed the problem or has even got a new one and we don't even know who the OP is anymore.
Closed Thread
