Wisconsin Robin engine problem
I have a Wisconsin Robin horizontal shaft model EH41D I believe it is 13 hp. This engine starts and runs but if you try to take the choke completely off it starts to sputter. This only happens when the engine is under a load. But if you leave the choke pulled half way it runs perfect.
I have rebuilt the carb but this does not help.
Any help would be appreciated
Thanks
Daniel
Thanks
Daniel
Hello Daniel!
Did you soak the carb in carburetor cleaner when you rebuilt it? There is a restriction in it that needs to be cleaned out.
Originally Posted by cheese
Hello Daniel!
thanks
Daniel
Received 2 Upvotes
Be aware that common bath cleaners are very powerful chemicals. Remove all rubber and all possible plastic pieces before soaking and use hand and eye protection when handling. By all means a good soaking should do the trick.
