Briggs & Stratton muffler stem removal
The muffler on my 3.5 horse Briggs lawn mower fell off and I need to remove the stem that remains in the engine block. Anyone have any ideas how to get it loose and out before I resort to the cutting torch?
Thanks.
Thanks.
Received 0 Votes
Poltergeist97,
The muffler pipe that is in the block should be a threaded screw in type. Please, no torch! You will need to soak the threads with lots of WD-40 or liquid wrench. Then carefully unscrew counter clock wise with locking pliers or drill a hole through the pipe and use a heavy screw driver to unthread it. Do your best not to damage the block or threads.
God Bless,
Dave237
God Bless,
Dave237
Received 0 Votes
Yeps, this job can be a pain to do,
patience
patience
patience
Lots of soaking with rust penatrator.
They dont come out easy, but do come out with work and effort and patience.
sporty
patience
patience
patience
sporty
Received 0 Votes
I used a 2inch C-clamp
I know this is about 8 years too late for yall but I used wd-40 and a pipe wrench to no avail. I then got a 2 inch clamp and seated it on both sides of the flange,tightnened it and gently tapped it with a rubber mallet. It moved and then i removed it and lather,rinse and repeat a few times I was able to remove the stem with my fingers. Hope this works for anybody else with this problem.
