weed eater
Old 09-15-05, 04:26 PM
waterman47
weed eater
I have a Featherlite Weedeater. I need to know how far into the fuel tank does the fuel line from the primer bulb need to go? Thanks
Old 09-15-05, 08:37 PM
repair_guy's Avatar
New Member
The main one (the one with filter)should be long enough to reach other end of tank.The other line is just a return line,and it just reaches about 1" into the tank.
Old 09-16-05, 03:51 PM
waterman47
weedeater
Thanks. I must be having a carb. problem. It will start and run for a few minutes and then stop. won't restart. Changed coil and that did'nt help.
Old 09-16-05, 03:57 PM
repair_guy's Avatar
New Member
Try re-routing the fuel lines first.Sounds like how they do when you have the lines reversed.Then if still wont do right,go into carb.Clean good and replace the diaphragm.
Old 09-17-05, 01:28 PM
also check the metal fuel filter screen in the carb.
should be able to see thru it and blow thru it easily
sporty
Old 09-19-05, 11:10 AM
waterman47
weedeater
Thanks guys. I will try those things.
