Honda GX620 on Dingo Mini Digger Looses Power
Old 09-27-05, 05:29 AM
A-ZParts
I have a Honda GX620 on a Dingo Digger that just don't have the power it use to. The unit is about 7 years old. Motor just doesn't run as good as it use to. Could it be the age? It has been used alot. It get serviced once a year. Oil change, filter, plugs, the works.
Old 09-27-05, 05:16 PM
Welcome A-ZParts,
After seven years of hard work I would suspect it is getting worn. A thorough carb cleaning and overhaul will most likely do the trick however, if this engine has seen very severe duty it may be time for a rebuild especially if it uses oil to any degree.
God Bless,
Dave237
