RL86C Repalcement
Old 10-11-05, 10:39 PM
RL86C Repalcement
Cheese,
Can you recommend a replacement plug for the (Champion RL86C) plug in my 12hp Tech?
It seems to be to hot for my applictaion "heavey load". Is there a cooler plug that you know of, I can switch to.
God Bless,
Dave237
Old 10-13-05, 01:15 AM
cheese's Avatar
I generally use an RC12Yc in most all American OHV engines with good results.
Old 10-13-05, 02:52 AM
puey61's Avatar
If you want to stick with the "L" series plug (and I recommend you do, since you apparently have an older Tecumseh), I'd use a RL82C or L82C, with the first being a resistor plug.
Old 10-13-05, 10:15 AM
Thank you both. I appreciate it. I'll give em both a try and see which one works the best.
God Bless,
Dave237
Old 10-14-05, 12:59 AM
cheese's Avatar
I was wondering what kind of plug you had in that thing. I guess if it's quite old, I wouldn't know what plug it takes. About the only old tecumsehs I see around my area are 6 horse horizontals bolted to tillers.
Old 10-14-05, 02:17 AM
Cheese,
It's an OVM 120/ 1988 model. It's one I honed the cylinder in a while back (thanks for your and Puey's advice by the way). It calls for a RL86C.
I'm currently running a (crossed Ref. Autolite 425), their numbers are a bit confusing, but after doing some study on plug types it seems to be a very hot plug for such a very hot engine. Even with valves adjusted it is very hard starting after some heavy mowing. Once it cools (5 minutes) it fires up fine.
I thought I would try a cooler plug and see if it made a difference. Maybe it would dissipate some heat. I use this engine to mow some very tall and tough grass. I'm going to give both Champion "RC12YC" and "RL82C" a try this week end for the last mowing this year. I have a Champion and Auto Lite cross reference guide however, it does not list which plugs they do manufacture.
I have noted that the "C" series has a 3/4" reach to where the "L" series has a 1/2" or .472 reach. I will test before useing. I'll let you know the out come.
Thanks again and God Bless,
Dave237
Old 10-14-05, 02:50 PM
puey61's Avatar
Do not use the RC12YC as it will contact the piston and both the plug and piston will likely be toasted. The reach of the RC is too long!!!
Old 10-14-05, 03:53 PM
deanw
puey61 is correct. Here are the plug specs:
RL86C
Thread 14mm
Hex size 0.8125
Reach 0.5000
RC12YC
Thread 14mm
hex size 0.6250
reach 0.7500
Here are some other plugs you can use which cross reference to the RL86C:
NGK B6HS , AC Delco 46F , Accel 156 , Motorcraft AES4C
Denso W20FS-U , Bosch W8AC , Autolite 425
Old 10-15-05, 01:37 AM
cheese's Avatar
Yes...do NOT use the plug I mentioned. You don't want a hole in the piston. My goof!
I should have checked a bit further before reccomending a plug. When I think OHV, it usually means rc12yc, but not in this case. Sorry! I know exactly what engine you're talking about now, and should have known the plug differences even though I don't know the # off the top of my head.
I need some ketchup to go with this crow, lol!
Old 10-15-05, 09:26 AM
Thanks for all the info guy's.
Cheese, no problem. Yes, I did note that the reach was a 1/4" longer and checked it in the hole before running. I turned the crank slowly by hand and it did indeed touch the piston. No harm done.
The only cooler Champion plug I can locate is the RL82C that Puey recommend however, I would like to find an even cooler plug like the RC12, RJ17 or RJ19 but in the "L" series 1/2" reach, if one is manufactured?
I'll look over the options an see what I can find. Thanks again to all for your help!
God Bless,
Dave237
Old 10-16-05, 09:20 AM
puey61's Avatar
The coolest L-series you'll find is an L78. Are you running race fuel in this thing? If not, there's no need to go any cooler!
Old 10-17-05, 11:42 AM
Thanks for info Puey. Nope, not running high octane...LOL. Just trying different plugs. I got to add to the old spark plug collection.
God Bless,
Dave237
