Starting a tractor with 12-volt battery
suobs's Avatar
FL
10-16-05, 07:43 AM   #1
Can I use a 12-volt car battery to jump-start a lawn tractor with the small-type 12-volt battery?
Can I jumper across the tractor solenoid connections to start the tractor/test the solenoid?
puey61's Avatar
NY
10-16-05, 09:15 AM   #2
Yes, to both. Beware that you may have a defective/misadjusted safety switch...from the sounds of your post.
suobs's Avatar
FL
10-16-05, 09:46 AM   #3
I tried testing the switch continuity but it seems OK. Why the "beware"?
goldstar's Avatar
OH
10-17-05, 03:57 PM   #4
Safety. It's there to protect you and others.
puey61's Avatar
NY
10-18-05, 02:57 AM   #5
I just don't like to see people spend their hard earned money on parts that they don't need. When it comes to an electrical (starting circuit, in this case) issue a systematic diagnosis is in order to isolate the actual problem...it may just be a safety switch.
