B&S 14.5hp will not crank
grtechguy's Avatar
10-19-05, 06:10 AM   #1
grtechguy
1990 B&S 14.5 OHV motor will not crank over. It is installed in a Montgomery Wards Signature 2000 Elite lawn tractor.
I had the tractor on a charger overnight.
the starter clicks and engine moves about 1/8" of an
inch.
Tried this with Spark plug in and out.
When I remove the starter from the motor, it spins freely. I can also manually turn the engine using one hand. it's stiff, but moves. I pulled the head off, and I can see the piston move up and down as well.
Could I just have a weak starter?
v8driver's Avatar
10-19-05, 07:28 PM   #2
so it does the same, plug in and out....sounds like valves are ok. make sure the connections are good, then make sure the starter gear on the starter is good, and the ring gear on the flywheel is good. does the starter work alright when off? the flywheel turns over tight.....make sure the magneto hasn't slipped and is rubbing. also make sure the battery actually holds a charge. what cranking amp as well?
cheese's Avatar
GA
10-20-05, 02:08 AM   #3
How is the condition of the gear at the end of the starter drive? If it's bad, it can bind and jam the starter.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
puey61's Avatar
NY
10-20-05, 02:55 AM   #4
Don't assume the battery is good just because it was charged. Have it tested for voltage and amperage. Most automotive chain stores can do this for you. Also, be absolutely certain that each cable end (6 total) is good and clean.
grtechguy's Avatar
10-23-05, 08:41 AM   #5
grtechguy
Starter works great when pulled off. the gear is in great shape.
no diference if plug is in or out. I will have to get the battery checked out though.
Can I jump the mower with my truck or will it be to much? I have 900+ Cranking amp battery in the truck. Can I place the jumper cable right to the starter?
huntingbubba89's Avatar
10-23-05, 08:47 AM   #6
huntingbubba89
yes you can use your truck battery to crank it up. i have done that a couple times and it hasnt hurt nothing. but dont hook straight to the starter, instead just hook it up to your battery.
grtechguy's Avatar
10-23-05, 11:13 AM   #7
grtechguy
ok.....engine is cranking with the help of my pickup. but will not start. I'm thinking the plug is quite old and needs replacing.
grtechguy's Avatar
10-23-05, 11:14 AM   #8
grtechguy
also, what is the proper magneto positioning? it is touching the flywheel right now.
v8driver's Avatar
10-23-05, 07:30 PM   #9
gap the mag with a dollar bill, till it drags out with resistence, but doesn't tear, then spin the flywheel for catching. if it was loose? that may be it?
cheese's Avatar
GA
10-23-05, 09:26 PM   #10
The coil armature should be .010" from the flywheel magnet. A business card or matchbook cover works well for this if you don't have a brass feeler guage.
God bless!
grtechguy's Avatar
10-25-05, 04:17 PM   #11
grtechguy
OK...I have adjusted the magneto, installed a new plug. I can hear a little sputtering but, still not starting. what should I check next?
v8driver's Avatar
10-25-05, 05:07 PM   #12
so its turning over good now? have you checked the flywheel key? that is if it gets spark, still won't fire, a sheared key will still give spark but it'll be off timing.
grtechguy's Avatar
10-25-05, 06:03 PM   #13
grtechguy
here's were ignorance comes to play.... were do I find the flywheel key? what does it look like?
this is a model 287707 0220-01
James Sanders's Avatar
CANADA
10-25-05, 08:03 PM   #14
Take off the cover, and the flywheel. The key is the tiny long piece of metal that is inbetween the crankshaft and the flywheel. Sometimes its only visibially sheared if you take the flywheel off.
cheese's Avatar
GA
10-28-05, 12:59 AM   #15
If the flywheel hasn't been removed before, and the engine hasn't come to an abrupt halt (I mean ABRUPT), then I wouldn't worry about the flywheel key just yet.
What's the history on this mower? Was it in storage for a long time? Did it just die and now you're trying to get it fixed? You could have a fuel delivery problem, valve problem, ignition problem, etc...
Have you tried a new plug? Is the plug sparking?
God bless!
grtechguy's Avatar
11-03-05, 08:05 PM   #16
grtechguy
sorry about the long delay. unfortunatly I do not know the history of the mower. I was told by the previous owner that it just would not start any more.
I have checked for spark a few days ago (still part of this repair) and was getting spark. I have also installed a new plug.
I am getting fuel into the carb and the plug looked wet after trying to start.
Tonight I did find that the exhaust valve rod was not in the correct place, so the valve was not opening. I have put that back in place. but after all this, my battery went dead. it's on the charger now. I'll check it in the morning and see if I can get a responce from it.
grtechguy's Avatar
11-07-05, 06:55 PM   #17
grtechguy
Got it started while using jumper cables from my truck. but, the longest it will run is about 10 seconds. then it dies with a bit of white smoke.
cheese's Avatar
GA
11-08-05, 12:07 AM   #18
Can you choke it to keep it running longer? Did you set the valve clearances?
God bless!
grtechguy's Avatar
11-08-05, 04:15 PM   #19
grtechguy
it is set a full choke. not sure on the valves.. what is the procedure to set them?
cheese's Avatar
GA
11-08-05, 11:29 PM   #20
Set the piston to top dead center, adjust the rocker arm nut until there is .005" between each valve and the rocker arm. Also, if the rocker arm came off the exhaust valve, make sure the tappet is still over the valve stem.
God bless!
