Snow Blower Problem
Maggot_Himself's Avatar
11-12-05, 10:30 AM   #1
Maggot_Himself
Snow Blower Problem
Alright, So I have a Yard Machines Snowblower, that i have had problems with in
the past... mainly the belts...so today i was checking everything to make sure it
works for the up coming season.. and well.. i have a problem with the left side(if
you are standing behind it) augar. It spins freely..i replaced the blets for both
sides.. any ideas what might be going on? i have gotton astick stuck in the
augar at one point...and some string one time.. thanks in advanced
Maggot
mla2ofus's Avatar
TX
11-13-05, 04:13 AM   #2
You said" I replaced the 'blets' for both sides". Does this mean belts or bolts?
Mike
snoman's Avatar
CANADA
11-13-05, 03:31 PM   #3
Check on the auger side that doesn't turn, most likely you have a broken shear bolt. Each side will have one, they are there so that they will break before something expensive does.
snoman
11-24-05, 06:34 AM   #4
Maggot_Himself
Posted By: mla2ofus You said" I replaced the 'blets' for both sides". Does this mean belts or bolts Mike
The belts sir.
Posted By: snoman Check on the auger side that doesn't turn, most likely you have a broken shear bolt. Each side will have one, they are there so that they will break before something expensive does.
I will do that...
We got a good amount of snow already today. Happy Thanksgiving
