Briggs & Stratton Carb mechanism
Old 11-14-05, 03:00 PM
Hi All,
need help with my lawn mower engine.
its a B&S Quattro 40
this weekend the entire carb assembly shook loose by missing one bolt.
I inadvertly disconnected the springs and linkage.
Now I dont know how they go back.
Any tips on how the springs connect-
Any pictures available.
Thanks
Tony
Old 11-14-05, 08:52 PM
v8driver's Avatar
should use a windvane governor, anyway, the linkage on it is easy, the link, with the loop, loop up, short end hooked into the windvane flap (make sure the windvane moves freely) then the other end into the hole, on the throttle shaft, in that little hole there, the springs hook to the loop, then to the big hole, for the speed control, if it has one.
forgot to ask if it was a float type carb, or diapragm type.
Old 11-15-05, 09:20 AM
Thanks I'll try-
what about the other little spring?
Old 11-15-05, 10:59 AM
v8driver's Avatar
one big, one small? they should go with each other, not connected together, but both to the same two spots
Old 11-15-05, 05:13 PM
Thanks again-
I hooked them up and it runs.
Old 11-16-05, 12:11 AM
v8driver's Avatar
great to hear
