Retired
Old 11-15-05, 06:05 AM
Retired
I Have A Craftsman Leaf Blower 2 Cycle.........it Ran Well For 3 Years.......this Year As I Start Using It ........it Would Start Ok...run Steady For About 5 Minutes And Then Slowly Die Off....
I Sense That Its Overheating But I'm Not Sure...when It Cools Down It Re-starts Ok And Then The Same Problem Devlopes....i Used A 40 To 1 Gas Mixture..........however I Ever I'm Wondering If There Is A Flaw In The Mixture.........what Would Too Much Oil Do??? Versus Not Enough???????? Plus Is There Any Other Suggestions Besides Oil/gas Mixture...........
Thanks.............retired
Old 11-15-05, 07:40 AM
VALENTINO,
You will need to clean the air hole in the top of the gas cap.
God Bless,
Dave237
Old 11-15-05, 10:55 AM
v8driver's Avatar
some people even run 50:1, much lower ratio of oil, too much, only thing you risk is a clogged spark arrestor. try the cap, if that doesn't do it, could be the ignition coil failing, isn't likely though.
Old 11-15-05, 11:26 PM
cheese's Avatar
Sounds to me like either the carb needs cleaning or the gas cap vent is clogged.
