starter stripped
romod's Avatar
11-20-05, 04:27 PM   #1
starter stripped
I have an old 70's model "mighty mac" shredder/mulcher.for awhile now when i would pull the rope the starter would rotate but not catch the crank to turn over the engine but after a few pulls it would eventually lock on the crank,now it won't lock on no matter how many times i pull the rope.the thing runs good when i can get it locked on and started.i don't even see a way to get into it,to see what needs to be fixed.any way to fix this?
v8driver's Avatar
11-20-05, 06:42 PM   #2
what brand engine? you can take the shroud off, usually 4 bolts or so, you may have to remove stuff thats in your way,look around for the bolts on it, take the shroud off and if it uses a starter bowl on the engine, and on the recoil starter when you pull out the rope, a couple starter dogs pop out, they may be worn out, unless its a starter clutch, then the little balls inside sound worn.
romod's Avatar
11-20-05, 11:57 PM   #3
Briggs and Stratton 80200 to 80292 series
cheese's Avatar
GA
11-21-05, 12:03 AM   #4
Yep, sounds like you need to disassemble and clean the starter clutch. Possibly replace it.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
