Riding mower blades do not disengage when handle is raised
I bought a used riding mower (brand name not visible) and the blades keep spinning after handle is raised. What is causing this problem?
I have a Lowes rider and while trying to get the deck adjusted to cut a little higher at the first cutting level, I discoverewd that the handle for the height also controls the blade engagement. When the handle for moving the deck down moves, the belt for the blades also engages.
I have moved this post to Small Engine Forum for answers from our experts.
That would probably be a mower manufactured by MTD. There should be 2 brake pads that contact the top of the blade pulleys when the deck is raised to stop the blades. If these are worn out, the blades will continue to turn.
